MaaXBoard Hardware Design UPS Hat/Rechargable Battery for Maaxboard RT
  • Subscribers 358 subscribers
  • Views 1143 views
  • Maaxboard RT
  • battery
samr2
samr2 over 4 years ago
Good Day,
I wanted to ask if anybody knows a UPS Hat/Rechargable Battery for Maaxboard RT in the market that is tested and you can confirm it's working.
PiSugar products seems to work but it's expensive and I'm not sure that will work with MaaxBoard RT. I'll appreciate if you give your suggestions here.
Thanks in advance,
Cheers,
  • jwlembedded
    jwlembedded over 4 years ago +2 verified
    Currently, we have not done any compatibility testing with UPS solutions for the MaaxboardRT. However, the MaaxboardRT has onboard power regulation on both the 3v3 rail and 5v0 rails. These rails are exposed…
  • jwlembedded
    +1 jwlembedded over 4 years ago
    Currently, we have not done any compatibility testing with UPS solutions for the MaaxboardRT. However, the MaaxboardRT has onboard power regulation on both the 3v3 rail and 5v0 rails. These rails are exposed on the PI header at pins 2,4 for 5v and 1, 17 for 3v3. Appling a stable 5v source to these pins will enable the normal operation of the MaaxboardRT. The normal current draw will fluctuate drastically depending on what you are running and what power state the core is in. I would suggest a 5v @ 500mA min power source.
  • samr2
    0 samr2 over 4 years ago in reply to jwlembedded
    Awsome Thank you!
