MaaXBoard Hardware Design MaaXBoard Yocto maintenance
  • Subscribers 360 subscribers
  • Views 1255 views
  • yocto image build
  • maaxboard
ARB
ARB over 3 years ago
I am trying to build a Linux distribution for the MaaXBoard with Yocto Zeus. I am unable to fetch all of the required repositories. Can someone confirm that this build is still possible and that all of the git repositories specified are still active?
  • iambluechen
    iambluechen over 3 years ago
    me too
  • ARB
    ARB over 3 years ago in reply to iambluechen
    My inability to complete the build using the Yocto directions provided by Avnet were a combination of the following:
    1. Network issues at work. I can build at home with the following change.
    2. I cannot fetch the repository for tinycompress using bitbake. I had to git clone the .tar.gz file myself and place that file and a copy labeled .tar.gz.done into /imx-yocto-bsp/maaxboard/downloads. I did this before running bitbake for the first time as it seems to break my ability to git clone these files after it is run.
    I am waiting on a usb-uart cable to test whether the build is functional but the build completed without errors.
  • hex
    hex over 3 years ago in reply to ARB
    do you have slow SD card write/read issue? i mean SoC is capable at SDR104 mode but i get High Speed (which is slow compared to SDR104 mode). Google Coral development board utilizes sdr104 speed mode maaxboard cannot while both have same PMIC.
  • ARB
    ARB over 3 years ago in reply to hex
    It was just the issues outlined above with my office network and needing to manually download tinycompress. I just download new repositories at home now and everything is fine.
