MaaXBoard Hardware Design Android - System crash and reboot when wifi connection is established
  • Replies 16 replies
  • Subscribers 358 subscribers
  • Views 3661 views
  • android
  • wifi
  • system-crash
  • maaxboard
zafersen
zafersen over 3 years ago
Hi there. I am trying to figure out a wifi issue on Android which causes the system to be crashed and rebooted. When I have a wifi connection or even search for available networks, suddenly the system is restarted due to some reason. Is there anyone who can shed some light on how I can debug or solve the issue? here is the logcat output below.
I got this log file by this command.
logcat2.txt
.\adb.exe logcat -d > logcat2.txt
  • javagoza
    javagoza over 3 years ago +1
    It seems that your device does not have installed or does not support Google Play Services.
  • zafersen
    zafersen over 3 years ago in reply to javagoza +1
    Sir javagoza , please just forget about google play services and additional all apps. I just flashed the out of box android image and the issue is still remaining.
    shabaz over 3 years ago
    How are you powering it? What model power supply? (Can you post a link to the exact power supply you're using, or a photo of the label on it).
  • zafersen
    zafersen over 3 years ago in reply to shabaz
    No worries I am sure there is no problem with power supply, it is 5a. Even USBs are supplied externally with 4A
  • javagoza
  • zafersen
    Hi,javagoza  Thanks for your reply. I just tried to install the google play store and services through adb push *.apk over usb connection. Those errors were caused by this reason. But before those errors, I had this wifi issue. even I couldn't install google services through wifi connection.  Do you have an idea about how I can debug and reach the reason for this wifi issue? is this logcat enough to understand? I have no experience in Android and very less in Linux.
    shabaz over 3 years ago in reply to zafersen
    You say you're sure, but I'm not : ) Please could you post a photo of the label on the supply (and a photo showing the connection on the supply and the connector/cable), or the link to the power supply you're using?
  • javagoza
    javagoza over 3 years ago in reply to zafersen
    You do not give information about what device you are using or what version of Android the device is running. So it is difficult to be able to help you.
    The three JVM restarts recorded in the log have been for exceptions for security reasons. I don't see anything related to the wifi hardware, I could be wrong.
  • zafersen
    I am working on the Maaxboard based on MIMX8MQ6CVAHZAA and android version is 9 comes with a reference design Android 9 Out of Box Image (zip)
  • zafersen
    Yes, I thought the same thing, I couldn't see any errors related to wifi hardware in the log file I shared above. that's why I thought that I may have looked at the wrong log file.
    javagoza has just spent considerable time examining your log file, and for what it's worth, I examined it too. We are trying to help you, so why don't you help us, and provide the power supply detail requested? All signs so far (from what you have specified so far) suggest a supply issue. This might not be the case, but let us rule out the most likely causes, since with respect, I don't know your experience, and I'm not just going to trust that the power supply is fine, without examining the detail that you ought to be providing.
  • javagoza
    I don't know that platform. I would check what version of google play services apk you have installed. It has to be a version compatible with the OS version you are using and compiled for that chipset architecture.
