MaaXBoard Hardware Design MaaXBoard-RT: WiFi CLI example - for you
  • Subscribers 358 subscribers
  • Views 438 views
  • wifi
  • MaaXBoard-RT
  • SDK example
  • AP
  • cli
  • sdk
tjaekel
tjaekel over 3 years ago
Converting the "wifi_cli_cm7" SDK example works:
GitHub - tjaekel/MaaXBoard-RT_wifi_cli_cm7: MaaXBoard-RT with WIFI demo (connect to AP, provide an AP)
I can:
  • access my home WiFi network (connect to an AP), from command line
  • create an AP: the MaaXBoard-RT acts as an AP, from command line
  • I can ping both (but there is not any reasonable data/web page to connect to)
Just needed to do:
modify in the "app_config.h" into:
//#define WIFI_IW416_BOARD_MURATA_1XK_M2
#define WIFI_88W8987_BOARD_MURATA_1ZM_USD
And you have to reset the board, or power-cycle (all the time):
after a new FW version flashed, the Murata chip was not reset - you get an initialization error.
Reset board (or power cycle) and the new FW should run.
(unfortunately, you lose connection to debug).
Remark:
Bluetooth is not enabled, not used (by this example).
If using Bluetooth - it would need a change for the LPUART10 used (not LPUART2 as on EVK - see board Guide Lines).
