MaaXBoard Hardware Design AES-MC-SBC-IMX8MINI-G power ON problem
  • Replies 13 replies
  • Subscribers 358 subscribers
  • Views 3009 views
  • AES-MC-SBC-IMX8MINI-G
Innodisk_malcolm
Innodisk_malcolm over 3 years ago
I have an AES-MC-SBC-IMX8MINI-G with power ON problem, there is no LED light after I plug Type-C adaptor, because there is no local AVNET FAE can support this product in Taiwan,  I try to ask experts here.
AES-MC-SBC-IMX8MINI-G by Avnet Engineering Services Evaluation & Development Kits | Avnet
  • javagoza
    javagoza over 3 years ago +1
    Have you pressed the S3 PWR button? S3 is the system power button for the board.
  • javagoza
    0 javagoza over 3 years ago
  • peterfenn
    0 peterfenn over 3 years ago in reply to javagoza
    Just to be clear: Functions of the three buttons are defined as follows:
    S1: USER button #1 (Back)
    S2: USER button #2 (Home)
    S3: PWR button
    The S3 PWR button supports
    Short press (1 sec) : To power-up / or to Reboot
    Long press (8 sec)  : To enter Standby...
  • Innodisk_malcolm
    0 Innodisk_malcolm over 3 years ago in reply to peterfenn
    Dear Peterfenn,
      Thanks for your tips,
    we connect LCD panel & Type-C adaptor than press S3 PWR, unfortunately it still not been powered ON.
    We have two sets of AES-MC-SBC-IMX8MINI-G, adaptors, and LCD panels try to swap but we got the same result!
    Thank you so much!
  • fouad_jh
    0 fouad_jh over 3 years ago
    There are few things you can do:
    1- Verify that the power supply USB C works fine on some other device. You might be able to test by unpluging and replugging USB C to the bord, a green light will illuminate for a short period.
    2- Do you have the correct Linux Image correctly flashed into the microSD card? There is no microSD card inserted as in the photo attached, the board won't show any activity without being booted!
    3- Remove the LCD at this stage. If you want to use the LCD fucntional, you will need the right Linux image.
  • Innodisk_malcolm
    0 Innodisk_malcolm over 2 years ago in reply to fouad_jh
    Hi fouad_jh,
      Thanks for your suggestion, we can bring up the system now!
    however, the display is not working correctly, we try both Debian & Andriod , the result is the same!
    Please kindly guide us to fix this issue.
    we got the LCD on AVNET website: AES-ACC-MAAX-DISP2 by Avnet Engineering Services LCD Displays | Avnet
    Thank you!
    BR,
    Malcolm
    system successfully bring up!
  • fouad_jh
    0 fouad_jh over 2 years ago in reply to Innodisk_malcolm
    For Linux, as in the user guid: https://www.avnet.com/wps/wcm/connect/onesite/bad2e2f0-d31a-4d81-8693-cc1de264ef56/MaaXBoard_Mini-Linux-Debian-UserManual-V1.1-EN.pdf?MOD=AJPERES&CACHEID=ROOTWORKSPACE.Z18_NA5A1I41L0ICD0ABNDMDDG0000-bad2e2f0-d31a-4d81-8693-cc1de264ef56-nygeq5z
    Section 3.4.1
    You will need ot reboot after updating uEnv.txt.
  • Innodisk_malcolm
    Dear fouad_jh,
      Thanks for your information, we try different dtb but abnormal display still remain.
    is there any suggestion?
    Thank you so much!
  • fouad_jh
    Hi Malcolm,
    Can you log and attach boot messages?
  • fouad_jh
    Use external Monitor with HDMI (you might need to update uEnv.txt with the correct dtb file).
    In the release note, it states that there is a known issue with MIPI screen after reboot. I am not sure if that is the case if you power off the board then back on.
    I hope that helps.
  • Innodisk_malcolm
    Hi fouad_jh,
     Our kit does not have HDMI port, we have to rely on the LCD to display monitor.
    Good news is we can light the LCD panel by rebuild the Yocto BSP in this link,
    GitHub - Avnet/meta-maaxboard: Yocto meta-layer for MaaXBoard/Mini/Nano /Plus
    however, our target OS is Debain and we can not display LCD after we rebuild the Debain BSP,
    GitHub - Avnet/maaxboard-debian-build: Scripts to build debian Lite/Desktop image for MaaXBoard / Mini / Nano / Plus
    could you guide us to resolve this issue?
    Thank you ~!
    BR,
    Malcolm
