MaaXBoard Hardware Design Picozed FMC carrier card with Picozed 7015 SOM is not working
  • Subscribers 358 subscribers
  • Views 572 views
nithinsteffy
nithinsteffy over 2 years ago
Hi Team,
I've been working with Picozed FMC carrier card with Picozed 7015 SOM for the last few weeks, it was working fine.
Recently i found that the clock was not getting properly on the PCLK pin, which was allocated for clk_out in my vivado design
And now i'm unable to flash my code via JTAG , it was not detecting the board. Even the D3, D4 LEDs was not indicating any.
What may be the reason?
  • aswinvenu
    aswinvenu over 2 years ago +1
    Looks like Picozed FMC carrier is not detecting Picozed 7015 SOM. First thing I would check is the power supply lines. Check 3v3, 1.8 and 1.0 volt lines. Give the board to board connectors a nice IP…
  • aswinvenu
    0 aswinvenu over 2 years ago
    Give the board to board connectors a nice IP wash. See if that helps as well.
    Aswin
  • nithinsteffy
    0 nithinsteffy over 2 years ago in reply to aswinvenu
    Hi  Aswin,
    I tried it, but the problem remains same. And also i can't find any short circuit or visible damage.
    How to solve the problem?
