MicroZed Hardware Design Embedded linux and video stream
  • Subscribers 362 subscribers
  • Views 444 views
I have a system including sensor camera connect to microzed board.
Microzed run by linux kernel 3.8. Sensor camera output raw data(UYVY), I have C program on microzed board read data from sensor camera after compress to jpeg data.
Request:
Client using web browser access to webserver on microzed board (http://192.168.35.45:8080) view video get from sensor camera.
How can I do it?
Please help me!
Sorry for my English.
  • zedhed
    0 zedhed over 11 years ago
    Hi ctbk1989,
    If you are already running Linux and have an application which captures the image sensor data and writes to a JPEG file, you have the hard part completed.
    Open source web server applications are available that you could run on MicroZed in order to serve up the image files that exist on the file system. Once you have the webserver up and running, you would probably want to create a page with a GUI that allows navigation to the latest image files.  At that point, the page becomes web development work.
    -Kevin
    I did as you said but the images display very slow. Require the time image display must be real time.
