MicroZed Hardware Design PWM peripherals reference design needed
  • Subscribers 362 subscribers
  • Views 557 views
nitron
nitron over 13 years ago
    In my humble opinion a PWM peripherals IP(reference design) for MicroZed/Zynq or a tutorial with this topic will be highly acclaimed.
    I think it will be very usefull if Avnet/Xilinx would be able to provide IP for PWM peripherals with memory mapped registers. This in order to enable programmatically:
     -change the PWM period
     -configure the dead-time of the power transistors
     -change the polarity of the PWM outputs
     -enable or disable the PWM outputs
In my experience a good inspiration for the "state of the art" are the PWM peripherals of TI for the Concerto or Delfino products.
This will considerably help the transition of folks (like me) comming from the microcontrollers domain and trying to migrate to Zynq based products. Since we have little experience in VHDL/Verilog implementation such kind of IP will speed up the transition.
A reference design for Motor Control providing the IP for the main peripherals found on a microcontroller (PWM, ADC, Capture Units/Encoder) will also help the penetration of MicroZed and Zynq.
I could find such a reference design for Altera / competing Cyclone V device but not for Zynq :
http://www.altera.com/support/refdesigns/sys-sol/indust_mil/ref-drive-chip-multi-axis-motor-control.html
Any plans about that?
  • mbrown
    0 mbrown over 12 years ago
    Thanks very much for your recommendation and request.  Please stay tuned in the coming weeks.  We have been building upon our successful Spartan-6 FPGA Motor Control Development Kit, working towards a ZedBoard-based platform with more features and reference designs.
  • mbrown
    I forgot to mention that Avnet's partner Qdesys has developed top-notch IP for advanced motor control, including the building blocks you mentioned in your post.
    They have a ZedBoard community project posted here:
    http://www.zedboard.org/node/645
    I am a greener of zynq , and also need such a IP core for design.Have you gotten this,look for your help .
    Regards
  • mbrown
    0 mbrown over 11 years ago in reply to e14 Contributor
    The Zynq Intelligent Drives Kit II features an Analog Devices open-source reference design that runs Linux on the Zynq PS and real-time motor control in the Zynq PL.  The controller is a simple 6-step design for Brushless DC motors, but the framework of the Zynq design allows you to replace that controller with your own custom controller.
    The design is available on the Analog Devices wiki page for AD-FMCMOTCON2-EBZ
    http://wiki.analog.com/resources/eval/user-guides/ad-fmcmotcon2-ebz
    You may also find an example of Field Oriented Control that ADI published for the previous version of the kit at this link:
    http://wiki.analog.com/resources/eval/user-guides/ad-fmcmotcon1-ebz/reference_hdl/linux
    Matt
