MicroZed Hardware Design Zynq Reset
  • Subscribers 362 subscribers
  • Views 1107 views
Zynq Reset
Dear all,
i want to reset the zynq. the code that is used for this purpose according to TRM document is
Xil_Out32(XPS_SYS_CTRL_BASEADDR + 0x00000200,0x00000001);
but nothing happened.
please help me where is wrong, should i do something before this code?
sincerely yours.
  • zedhed
    0 zedhed over 10 years ago
    Hi zara,
    Take a look at UG585 where this information is taken from:
    http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
    Access to XPS_SYS_CTRL_BASEADDR address space is not allowed since the system controller memory space is protected from accidental modification.  If you look at page 1581 of the Zynq Technical Reference Manual, which covers the 0xF8000000 SLCR space, you can see that SLCR_LOCK register description shows the following text for the LOCK_KEY bits [15:0]:
    "Write the lock key, 0x767B, to write protect the slcr
    registers: all slcr registers, 0xF800_0000 to
    0xF800_0B74, are write protected until the unlock
    key is written to the SLCR_UNLOCK register. A
    read of this register returns zero."
    Likewise the SLCR_UNLOCK register description shows the following text for the UNLOCK_KEY bits [15:0]:
    "Write the unlock key, 0xDF0D, to enable writes to
    the slcr registers. All slcr registers, 0xF800_0000 to
    0xF800_0B74, are writeable until locked using the
    SLCR_LOCK register. A read of this register
    returns zero."
    Try following this information to unlock access to the register before writing to it and see if this works for you.
    -Kevin
    0 e14 Contributor over 10 years ago in reply to zedhed
    Hi Kevin,
    thanks a lot for your prompt reply.
    I followed your information and it works.
    Best Regards,
    Zara.
