MicroZed Hardware Design IBIS files for MicroZed
  • Subscribers 361 subscribers
  • Views 622 views
Is it possible to get the IBIS model for the MicroZed board?
There are some simulation through Hyperlynx I plan to do and would need to use the IBIS files for that purpose.
The MicroZed board I have is AES-Z7MB-7Z020-SOM-G
Thanks a lot!
  • drozwood90
    0 drozwood90 over 9 years ago
    Hi there,
    We do not have an IBIS model of the entire MicroZed.  What users typically do is export the IBIS model of the Zynq-7020 and then couple that with the net lengths.
    You can find instructions on exporting an IBIS model in UG899, chapter 3 (in the August 8 2012 revision, page 51).
    https://www.xilinx.com/support/documentation/sw_manuals/xilinx2012_2/ug899-vivado-io-clock-planning.pdf
    The Net lengths are listed on the Microzed.org website:
    http://microzed.org/support/documentation/1519
    Search the page for "MicroZed Net Lengths"
    --Dan
    0 e14 Contributor over 9 years ago in reply to drozwood90
    Thanks for the quick reply. I will do the extraction. How to add the consideration for the 100 pin connector?
  • drozwood90
    Hi there,
    I have made a request for the IBIS model, in the mean time, I have been asked to request that you head over to www.fci.com and use the web chat.  Put in the part numbers of BOTH the MicroZed and the Carrier card connectors and request an IBIS model.  They tell me that a SI Engineer will be able to help you get the information that you need!
    --Dan
