MicroZed Hardware Design device tree generation
  • Subscribers 361 subscribers
  • Views 400 views
hi
I am unable to compile the device tree from vivado sdk , i follow the xilinx tutorial but it doesnt work comes up with failed to generate bsp sources .
Is there a work around ?
I am using the Microzed board 7020 .
thanks
    You're going to have to help me out with a little more information here.   I typically use a Linux environment to build device trees from the command line using the dtb compiler supplied in the GNU toolchain.   There is a chapter in the Ubuntu tutorial for ZedBoard (applicable to the MicroZed as well) that describes this procedure.  Which Xilinx tutorial are you referring to?
    Ron
