MicroZed Hardware Design Ethernet connectivity with MicroZed
  • Subscribers 362 subscribers
  • Views 750 views
raunaq
raunaq over 9 years ago
Does anyone know how to transmit data through Ethernet demonstrating connectivity with any IP cores, for example reading from memory through DMA and transmitting it through Ethernet or taking an input signal and sending it out through Ethernet.
I'm unable to find any example. I ran lWIP echo server example with MicroZed, which is particularly just a connection test.
Any suggestions/examples would be great, using MicroZed!
Thanks!
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Raunaq,
    I am going to suggest you take a look at the MicroZed Chronicles, specifically issues 77, 78, and 79. http://zedboard.org/content/microzed-chronicles
    --Josh
  • raunaq
    0 raunaq over 9 years ago in reply to jafoste4
    Hi Josh, thanks for replying for sending the links. I did at look at those and try to implemented it (Ethernet 2 article) -  I'm seeing some random data on COM port side. But I don't see any ethernet connection nor data transfer between MicroZed and PC. I don't see anything in blog post either him showing results from the Ethernet.
    I'm just trying to send simple data transfer from MicroZed to PC.
  • jafoste4
    Hello Raunaq,
    Try taking a look through these resources.
    http://zedboard.org/content/understanding-ethernet-zedboard
    http://zedboard.org/content/ethernet-bare-metal-application
    http://zedboard.org/content/raw-ethernet-frames-xemacps-driver
    http://zedboard.org/content/ethernet-driver-bare-metal-application
    Also you should take a look at the echo server example application in SDK. It generates a TCP/IP protocol stack.
    --Josh
  • jafoste4
    Hello Raunaq,
    Also reference this website. It has example designs done on the microzed and zedboard for you to look at.
    http://ethernetfmc.com/exampledesigns/
    --Josh
