MicroZed Hardware Design EPC "External peripheral controller" connect DATA BUS by bidirectional bus
  • Subscribers 361 subscribers
  • Views 1142 views
Hello, I want to connect to the AXI bus external device, using "External peripheral controller" . In the Datasheet it is written as to connect the address bus, data bus, etc.. I need to connect the data bus as bi-directional, but in the controller there is no signal to the bidirectional bus, but only separately.
How can I connect my controller to the data bus was bidirectional?
  • drozwood90
    0 drozwood90 over 10 years ago
    Hi there,
    You can probably just use the the prh_wr_n signal.  If that does not work with the setup/hold of your device, you will need to generate the logic you need.
    See Figure 1-4 of the axi-epc documentation:
    http://www.xilinx.com/support/documentation/ip_documentation/axi_epc/v2_0/pg127-axi-epc.pdf
    Notice in that figure there is "external glue logic".
    --Dan
    Thank you! Had to use IP "Select IO Interface Wizard".
