MicroZed Hardware Design Logic Speed
  • Subscribers 361 subscribers
  • Views 322 views
Logic Speed
We know 7010/20 haven't high speed serial transceiver. But event without it, how much speed can we have in LVDS pairs?
And reading parallel data, how much speed can I reach in each pin from FPGA ?
  • zedhed
    0 zedhed over 12 years ago
    Hi robertoalcantara,
    If you are familiar with FPGA design then you know that there are a lot of variables which go into a design in order for you to meet timing across all your logic.
    However, I believe that the information you are looking for is contained within the Xilinx DS187 document:
    http://www.xilinx.com/support/documentation/data_sheets/ds187-XC7Z010-XC7Z020-Data-Sheet.pdf
    According to this datasheet, for 7010/7020 -1 speed grade devices, single data rate LVDS transmitter using an OSERDES primitive can achieve up to 600Mbps.
    I think your parallel data question is a little more complicated since it seems like it would be dependent upon the I/O standard being used i.e. 3.3V has slower switching than 1.8V I/O.
    -Kevin
