MicroZed Hardware Design onboard clock loses time on power disconnect
  • Subscribers 362 subscribers
  • Views 428 views
The MicroZED does not retain time between boots. Is it possible to add a battery to the board to that it will retain time between boots?
    Hello Andrew,
    No. You would need to provide this capability via a custom carrier card for the MicroZed.
    -Gary
  • zedhed
    0 zedhed over 11 years ago
    Hi Andrew,
    You could also add and RTC to your MicroZed system.
    If you are using one of our MicroZed carrier boards, this could be done with the Maxim DS3231 RTC Pmod:
    http://datasheets.maximintegrated.com/en/ds/DS3231MPMB1.pdf
    -Kevin
