MicroZed Hardware Design ethernet with pulsar linux
  • Subscribers 362 subscribers
  • Views 1027 views
scottp00
scottp00 over 9 years ago
Hi.    I'm running pulsar linux 8 on a Z7010 board.   When I generate a new BOOT file, linux shows the ethernet interface is always down.  If I use the original BOOT file, it functions normally.   I am using Vivado/SDK 20717.2 to generate.   I also noticed that when using the default BOOT file, linux sees the ethernet driver as a Marvel88E1510 but under the new file it shows Generic PHY.   Any help would be appreciated.   Thanks
  • hannahburh12
    0 hannahburh12 over 9 years ago
    Have you tried plugging in the Ethernet while generating a new boot file? I had a similar issue not so long time ago, will try to check how I fixed it.
    Han
  • scottp00
    0 scottp00 over 9 years ago
    I found a fix for this.  Use the provided FSBL file instead of generating one in the SDK
    http://zedboard.org/sites/default/files/design/MZ_IIoT_HW_Tutorial_VIV2016_2.zip
