MicroZed Hardware Design Power Estimation - where is XPE file ?
  • Subscribers 360 subscribers
  • Views 467 views
The Microzed Carrier Design Guide pg. 16 suggests there is an XPE file available on MicroZed.org. I would like to look at this for power estimation. Anyone know where I can find it ??
Cheers
  • bhfletcher
    0 bhfletcher over 12 years ago
    This is now posted. Be aware that this original estimate was prepared with the 14.4 version of XPE. I would highly recommend that you download the latest 2014.2 XPE for your own power measurements.
    MicroZed_XPE_2014_2_7010_140625.zip
    Bryan
  • bhfletcher
    0 bhfletcher over 12 years ago in reply to bhfletcher
    I updated this to 2014.2 XPE, with a few modifications. Note that this uses 95-97% of the logic, 100% BRAMs, 100% DSPs, 100% MMCM/PLLs, and 100% of the PL I/Os. That may not be realistic for your design, so you should adjust.
    Also note that this is for a 7010-Commercial, so adjust appropriately for 7020, Industrial, temperature conditions in your environment, etc. This is only meant to be a starting point. Please provide feedback if you see any oversights.
    Bryan
