MicroZed Hardware Design Can't install petalinux on microzed board by uSD card
  • Subscribers 363 subscribers
  • Views 796 views
nguyenductoan
nguyenductoan over 8 years ago
I am using Vivado 2016 which only support Zedboard target. Already set JP1,2,3 to SD mode. I can not boot any thing from uSD card, seem to be interface uSD is not detected. I search many topics then they said need to set CD and MIO 0 pin to 0 when durring SD boot mode, but it is fixed when design in Vivado. So anyone can help me how to set CD or MIO 0 pin to 0 or other solutions. Thanks
  • jafoste4
    0 jafoste4 over 8 years ago
    Are you trying to build petalinux from scratch or are you using one of the MicroZed BSPs?
    --Josh
  • nguyenductoan
    0 nguyenductoan over 8 years ago in reply to jafoste4
    Thanks JFoster !
    I had done build petalinux on board cause i forgot to install board files supported for microzed board.
    Thank you !
  • edwardkelly71
    0 edwardkelly71 over 8 years ago in reply to nguyenductoan
    I made the same mistake few weeks back. Good to see, I'm not the only one who forgot about it ;)
    Edward
