MicroZed Hardware Design Transfer data from DDR to SD card in VHDL
  • Replies 7 replies
  • Subscribers 362 subscribers
  • Views 1178 views
ttkee
ttkee over 8 years ago
I am looking to transfer data from the zynq ddr to a custom ip, then store the result on the sd card. The sd card is connected through the emio pin, so it is available to the PL. So far, I can access the DDR from Windows, so I put files there. All I need is to connect each component in vhdl to send and receive data from each other. My current Block diagram has AXI stream FIFo, AXI DMA, BRAM generator, and BRAM controller. I've read different tutorials, and only find how to set up the hardware, but not how to connect each piece. Any ideas?
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Ttkee,
    Could you tell me what hardware platform you are using for development?
    --Josh
  • ttkee
    0 ttkee over 8 years ago in reply to jafoste4
    I am using VIvado 2017.4.
    Here is my block design image
  • ttkee
  • ttkee
    Having problem uploading. Here it is.
    https://image.ibb.co/hwZTZx/bd.jpg
  • jafoste4
    Are you using MicroZed, Zedboard, PicoZed, UltraZed?
    --Josh
  • ttkee
    The board I am using is the zybo z710 board
  • jafoste4
    Please contact digilent for support with their ZYBO product.
    Thank you,
    Josh
