MicroZed Hardware Design RF board for microzed
  • Subscribers 362 subscribers
  • Views 796 views
suppamax
suppamax over 11 years ago
I'm looking for an RF board to finish developing my SDR application based on microzed.
I was considering AD-FMCOMMS3-EBZ (which I know to be compatible with the zedboard) and I was wondering if I might use it with microzed.
If not, would you suggest any alternative?
Thanks a lot,
Max
  • mbrown
    0 mbrown over 11 years ago
    Yes, MicroZed is compatible with AD-FMCOMMS3-EBZ, which accepts a Vadj voltage up to 3.3V.  The MicroZed FMC Carrier can generate 1.8, 2.5V, or 3.3V Vadj.
    http://zedboard.org/product/microzed-fmc-carrier
    Matt
  • suppamax
    0 suppamax over 11 years ago in reply to mbrown
    Just to be sure: the same is valid for FMCOMMS2, isn't it?
  • mbrown
    Yes, FMCOMMS2 also accepts Vadj voltage up to 3.3V.  You can verify this by finding the schematics for the FMC modules here:
    http://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/introduction
    Matt
  • suppamax
    do you know how shall I configure the jumpers of the FMC carrier board?
    In particular I don't know what the FMC ADD one are for...
    Max
  • mbrown
    I realized that I had a mis-type in my previous response.  I meant to clarify that MicroZed FMC Carrier can provide 1.8v,2.5V and 3.3V.  HOWEVER, the FMCOMMS2/3 modules can NOT be powered at 3.3V.  You must set the carrier Vadj voltage to either 1.8V or 2.5V.  We use 2.5V in our examples.
