MicroZed Hardware Design Microzed, program of flash memory
  • Replies 9 replies
  • Subscribers 362 subscribers
  • Views 1642 views
elynum
elynum over 8 years ago
When I program flash memory it tells me that I have succeded but when I unplug the power and plug back up the fpga does not come up with my code.  I can only program with jtag.
  • jafoste4
    0 jafoste4 over 8 years ago
    Did you switch your jumpers to QSPI boot?
    --Josh
  • elynum
    0 elynum over 8 years ago in reply to jafoste4
    Yes, I switched it and still it doesn't come up.
  • jafoste4
    Hello Elynum,
    Did you verify it worked properly over JTAG first? Did you create a FSBL? What exactly are you trying to program into the QSPI?
    --Josh
  • jafoste4
    Hello Elynum,
    --Josh
  • elynum
    Yes, I verified it worked over jtag no problem, It's just a simple LED blink program with some serdes logic
  • jafoste4
    Hhello elynum,
    Create a Hello World Application and try to program that into the QSPI. If you are unable you may be following incorrect steps to program the QSPI. What Vivado/SDK Version are you using? I can refer you to a suitable reference design that shows the steps.
    --Josh
  • elynum
    Vivado 2017.1.  I didn't think I would have to use SDK to program flash shouldn't I be able just to do it with vivado.  What I don't understand is, it says program succeeded.
  • jafoste4
    Hello elynum,
    I was assuming you were writing an application in C and not strictly using Verilog/VHDL. Yes you can prgoram straight from Vivado. Can you add an ILA core into your design and use the HW manage to watch the logic levels you are setting. Doing this you can compare the difference between having the image in the QSPI and the JTAG boot options.
    --Josh
  • bhfletcher
    0 bhfletcher over 8 years ago
    This topic might be relevant:
    https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Working-without-IP-PL-only/td-p/656019
    Bryan
