MicroZed Hardware Design Pin errors in microzed FMC carrier guide
  • Subscribers 361 subscribers
  • Views 546 views
The microzed FMC carrier card hardware users guide rev 1.0 Feb 25 2014 has many incorrect Zynq pin connections given in Table 9 and 10 going to the FMC slot.
Table 10 for JX2
LA23_P goes to zynq L19 not M19 (LVDS 6)
LA23_N goes to zynq L20 not M20
LA24_P goes to zynq M19 not M17 (LVDS 7)
LA25_N goes to zynq M20 not M18
There are more then just these....
It appears that no one reviewed this PDF document for errors.
Also I have not idea why it has another table section that are only for the I/O carrier PMODS and there is no real table provided for FMC connector going back to Xynq pins except for Table 9 and 10.
I would really hope that Avnet would rewrite this user guide and make sure it has been carefully checked.
Lets hope the bad connections given in the tables did not cause my FMC card harm.
James
    James,
    Thanks for catching and reporting the errors. We will update the guide.
    -Gary
    Gary,
    Do you know when the guide will be updated?
    Steve
    I was scratching my head until I just debugged by passing a know value u2026.
    I think the Pmod pins do not match the IO they are referring to .. example M19 goes to JF pin3 and not pin1 .. etc.
