MicroZed Hardware Design MZEMBV hdmi passtrough reference design vivado 2015.4
  • Replies 8 replies
  • Subscribers 365 subscribers
  • Views 2316 views
irelectronic
irelectronic over 9 years ago
According to the steps in the EMBV_HDMI_Passthrough_Tutorial_2015_4_01.pdf document, the embv_hdmi_passthrough_MZ7020_EMBV_20160223_195702 file is not available on the specified path. Is there a way to build a project? Or someone email me a project built for 2015.4 or later?
thanks all
  • jafoste4
    0 jafoste4 over 9 years ago
    Please specify what step you get stuck on and I will take a look into what you problem may be.
    Thank you,
    Josh
  • rutberg
    0 rutberg over 9 years ago
    It looks like irelectronic is having the same problem that I am.
    http://zedboard.org/content/embv-tags-missing-github
    All of the embv tags are missing from the Avnet GitHub repository.
    Any insight would be appreciated--
  • irelectronic
    0 irelectronic over 8 years ago in reply to jafoste4
    The text below is the messages generated during the implementation of the TCL. I do not know why it gives Error.
    ****** Vivado v2015.4 (64-bit)
      **** SW Build 1412921 on Wed Nov 18 09:43:45 MST 2015
      **** IP Build 1412160 on Tue Nov 17 13:47:24 MST 2015
        ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
    Vivado% cd C:/Avnet/hdl/Scripts
    Vivado% source ./make_embv_hdmi_passthrough.tcl
    # set argv [list board=MZ7020_EMBV project=embv_hdmi_passthrough sdk=yes version_override=yes]
    # set argc [llength $argv]
    # source ./make.tcl -notrace
    *-        Welcome to the Avnet Project Builder         -*
    | Setting          |     Configuration                  |
    | Board            |     MZ7020_EMBV                    |
    | Project          |     embv_hdmi_passthrough          |
    | SDK              |     yes                            |
    | Version override |     yes                            |
    Overriding Version Check, Please Check the Design for Validity!
     Selected Board and Project as:
    MZ7020_EMBV and embv_hdmi_passthrough
    Not Requesting Tag
    Setting Up Project embv_hdmi_passthrough...
    ***** Generating IP...
    ***** Creating Vivado Project...
    ***** Updating Vivado to include IP Folder
    INFO: [IP_Flow 19-234] Refreshing IP repositories
    INFO: [IP_Flow 19-1700] Loaded user IP repository 'c:/Avnet/hdl/IP'.
    WARNING: [IP_Flow 19-593] The IP 'Bitmap 2.5D Graphics Accelerator', version 0.0, is no longer found in the user IP repository D:/Xilinx/Vivado/2015.4/data/ip. It will not be included in the IP Catalog. (It used to be found at d:/Xilinx/Vivado/2015.4/data/ip/partners/xylon/logibmp.)
    WARNING: [IP_Flow 19-593] The IP 'Scalable 3D Graphics Accelerator', version 0.0, is no longer found in the user IP repository D:/Xilinx/Vivado/2015.4/data/ip. It will not be included in the IP Catalog. (It used to be found at d:/Xilinx/Vivado/2015.4/data/ip/partners/xylon/logi3d.)
    WARNING: [IP_Flow 19-593] The IP '2D Graphics Accelerator Bit Block Transfer', version 0.0, is no longer found in the user IP repository D:/Xilinx/Vivado/2015.4/data/ip. It will not be included in the IP Catalog. (It used to be found at d:/Xilinx/Vivado/2015.4/data/ip/partners/xylon/logibitblt.)
    WARNING: [IP_Flow 19-593] The IP 'Perspective Transformation and Lens Correction Image Processor', version 0.0, is no longer found in the user IP repository D:/Xilinx/Vivado/2015.4/data/ip. It will not be included in the IP Catalog. (It used to be found at d:/Xilinx/Vivado/2015.4/data/ip/partners/xylon/logiview.)
    WARNING: [IP_Flow 19-593] The IP 'Multilayer Video Controller', version 0.0, is no longer found in the user IP repository D:/Xilinx/Vivado/2015.4/data/ip. It will not be included in the IP Catalog. (It used to be found at d:/Xilinx/Vivado/2015.4/data/ip/partners/xylon/logicvc.)
    WARNING: [IP_Flow 19-593] The IP 'Audio I2S Transmitter/Receiver', version 0.0, is no longer found in the user IP repository D:/Xilinx/Vivado/2015.4/data/ip. It will not be included in the IP Catalog. (It used to be found at d:/Xilinx/Vivado/2015.4/data/ip/partners/xylon/logii2s.)
    WARNING: [IP_Flow 19-593] The IP 'I2C Bus Master Controller', version 0.0, is no longer found in the user IP repository D:/Xilinx/Vivado/2015.4/data/ip. It will not be included in the IP Catalog. (It used to be found at d:/Xilinx/Vivado/2015.4/data/ip/partners/xylon/logii2c.)
    WARNING: [IP_Flow 19-593] The IP 'SD Card Host Controller', version 0.0, is no longer found in the user IP repository D:/Xilinx/Vivado/2015.4/data/ip. It will not be included in the IP Catalog. (It used to be found at d:/Xilinx/Vivado/2015.4/data/ip/partners/xylon/logisdhc.)
    INFO: [IP_Flow 19-2313] Loaded Vivado IP repository 'D:/Xilinx/Vivado/2015.4/data/ip'.
    ***** Creating Block Design...
    Wrote  : <C:/Avnet/hdl/Projects/embv_hdmi_passthrough/MZ7020_EMBV/embv_hdmi_passthrough.srcs/sources_1/bd/embv_hdmi_passthrough/embv_hdmi_passthrough.bd>
    ***** General Configuration for Design...
    INFO: Currently the variable <design_name> is equal to "embv_hdmi_passthrough".
    CRITICAL WARNING: [BD 41-52] Could not find the abstraction definition specified by the vlnv: avnet.com:interface:avnet_hdmi_rtl:1.0
    CRITICAL WARNING: [BD 41-181] Type specified by the VLNV: 'avnet.com:interface:avnet_hdmi_rtl:1.0', cannot be found. Interface port: 'hdmii_io' cannot be created
    CRITICAL WARNING: [BD 41-181] Type specified by the VLNV: 'avnet.com:interface:avnet_hdmi_rtl:1.0', cannot be found. Interface port: 'hdmio_io' cannot be created
    ERROR: [BD 5-11] Error: running create_bd_intf_pin, not found intf_pin /embv_hdmii_yuv422/hdmii_io
    ERROR: [Common 17-39] 'create_bd_intf_pin' failed due to earlier errors.
        while executing
    "create_bd_intf_pin -mode Slave -vlnv avnet.com:interface:avnet_hdmi_rtl:1.0 hdmii_io"
        (procedure "create_hier_cell_embv_hdmii_yuv422" line 34)
        invoked from within
    "create_hier_cell_embv_hdmii_yuv422 [current_bd_instance .] embv_hdmii_yuv422"
        (procedure "create_root_design" line 38)
        invoked from within
    "create_root_design """
        (file "../../Scripts/ProjectScripts/embv_hdmi_passthrough_bd.tcl" line 464)
    Vivado%
  • irelectronic
    0 irelectronic over 8 years ago in reply to rutberg
    Yes. Unfortunately, Avant has poor support for its products.
  • irelectronic
    Hi all
      Is there anyone to help
      I get the error below when creating the EMBV_HDMI_Passthrough_Tutorial_2015_4 project.
      Has anyone made a project?
    Vivado% cd c:/Avnet/hdl/Scripts
    | SDK              |     yes                            |
    Not Requesting Tag
    create_bd_cell: Time (s): cpu = 00:00:02 ; elapsed = 00:00:06 . Memory (MB): peak = 297.227 ; gain = 68.508
        while executing
        invoked from within
        invoked from within
    Vivado%
  • jafoste4
    0 jafoste4 over 8 years ago
    Have you followed the instructions in the PDF for this reference design?
    http://zedboard.org/support/design/4681/46
    --Josh
  • giving
    0 giving over 5 years ago
    solved!
    The reason are as follows:
    1.The embv_hdmi_passthrough_bd.tcl :avnet_hdmi_rtl:1.0 while  interfaces :avnet_hdmi.xml  2.0,so change The embv_hdmi_passthrough_bd.tcl :avnet_hdmi_rtl:1.0  all to  avnet_hdmi_rtl:2.0 ,as are the vivado ver (for example 2017.4) and ip ver you are acturally in use.
    timage
  • narrucmot
    0 narrucmot over 5 years ago in reply to giving
    Nearly 3 years between postings on this thread.  Wow, that is some great perseverance!  Glad you got this working!
    --Tom
