MicroZed Hardware Design ADA Card with MicroZed
  • Subscribers 362 subscribers
  • Views 904 views
xzsawq21
xzsawq21 over 9 years ago
Hello
I have an ADA card that has two 40-pin GPIO connectors:
now I want to connect it to the PL side of MicroZed SOM .
I checked the below document:
http://zedboard.org/sites/default/files/documentations/MicroZed_HW_UG_v1_6.pdf
page 19 of 39 table 13 mentions that we have 50+49 free pins from the PL side:
is there any problems in my Plan to connect the ADA card to MicroZed Board?
can I order a MicroZed with Zynq-7020 speed grade -2?
Regards
  • jafoste4
    jafoste4 over 9 years ago +1
    Hello xzsawq21, Could you please provide a link to the ADA card that you have? Also we do not offer a MicroZed 7020 with a speed grade of -2. --Josh
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello xzsawq21,
    --Josh
  • xzsawq21
    0 xzsawq21 over 9 years ago in reply to jafoste4
    you can find it here:
    http://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=73&No=278&PartNo=1
    I mean the GPIO version of ADA card that has two 40-pin GPIO connectors:
    http://www.terasic.com.tw/attachment/archive/278/image/ADA_DE.jpg
    I want to make a compatible board that's similar to your Breakout Carrier Board.
    Please reply me as fast as you can.
    Regards
  • xzsawq21
    if you want more information about the I/O pins, you can look at page 13/14/15 of the below document (I have modified it):
    http://s4.picofile.com/file/8285558042/THDB_ADA_UserGuide2.pdf.html
  • xzsawq21
    plus can I order two JX1,JX2 connector with my order (both are onto Breakout Carrier Board)?
    I mean:
    http://uk.farnell.com/productimages/standard/en_GB/1705091-40.jpg
    http://www.digikey.co.uk/product-detail/en/amphenol-fci/61083-101400LF/61083-101400LF-ND/1045639
  • jafoste4
    Hello xzsawq21,
    Unfortunatly I do not have any experience with Terasic Daughter Cards. All I can offer is if you are looking to make your own carrier card then please make sure to follow the MicroZed Carrier Design Guide : http://zedboard.org/support/documentation/1519
    --Josh
