MicroZed Hardware Design Standard MicroZed Signal Trace Width/Spacing.
  • Subscribers 363 subscribers
  • Views 1102 views
After reviewing the needed info in the Netlist, I looked into both the MicroZed Hardware Guide as well as the Carrier Design Guide but could not seem to find this info.
Of course precise adjustments will need to be made depending on how the signals are routed on the carrier board (internal/external, etc), but just as a 'starting point' or rule of thumb I am wondering what the signalling trace width is on the MicroZed board itself (note, I am only concerned with the signal traces alone that feed out to JX1/JX2, not power, etc).
I do see in the Carrier Design Guide that 4x spacing is recommended, but I am wondering just what trace width I ought to 'at least' be starting out with for routing out my signals, and then work from there.
  • zedhed
    0 zedhed over 11 years ago
    Hi abalducci,
    I think the trace width numbers normally come from your PCB shop and are depended upon the target impedance for the PCB stackup that you are using for your carrier board.  That stackup is heavily dependent upon the complexity of your carrier design.
    For example, our PicoZed FMC Carrier has the following stackup:
    Top
    Ground
    Signal
    Signal
    Power
    Power
    Signal
    Signal
    Ground
    Bottom
    For 50-Ohm outer single ended signals, the trace width is 5 mils.  For 50-Ohm inner single ended signals, the trace width is 4.5mils.
    For 100-Ohm differential signals all layers, the trace width is 4 mils with 10 mil spacing.
    Are you in contact with your local Avnet/Silica FAE on this project?
    -Kevin
    0 e14 Contributor over 11 years ago in reply to zedhed
    Dear Kevin,
    Yes you are correct about there being specialized requirements based on the board shop, but this at least gives me a very useful guideline (i.e. traces no smaller than) to start with. Thanks for the info.
    Best,
    - Anthony
  • mahmoodv99
    0 mahmoodv99 over 5 years ago in reply to zedhed
    Hi..
    which layer used as the reference plane for 2nd signal layer ?
  • bhfletcher
    0 bhfletcher over 5 years ago in reply to mahmoodv99
    Which board? The MicroZed or FMC Carrier? Typically, any signal layer will use the nearest Ground or Power layer as the reference plane.
    Bryan
