MicroZed Hardware Design Embedded Vision Carrier  on  Z7010 ?
  • Subscribers 360 subscribers
  • Views 427 views
I have Microzed Evaluation Kit containing Z7010.
Will Embedded Vision Carrier board work with that?
As DevKit contains Z7020 SOM, not Z7010.
Please suggest, could I obtain only mentioned Carrier board, to use it with EvalKit?
  • bhfletcher
    The MicroZed 7010 is compatible with the Embedded Vision Carrier. However, the 7010 has less Programmable logic than the 7020, so there will be limitations for those reference designs that require more PL than the 7010 provides.
    Also, the 7020 has access to one 15 more I/O through Bank 13. With a 7010 plugged onto the EVCC, you lose access to:
    •   JY Pmod
    •   Audio Codec
    The 7010 is certainly enough to get you started.
    Bryan
  • albertabeef
    0 albertabeef over 11 years ago
    Note that the following design works with the MicroZed 7010 SOM:
       EMBV - HDMI Passthrough Reference Design, Vivado 2014.4
       http://microzed.org/sites/default/files/design/EMBV_HDMI_Passthrough_Tutorial_2014_4_01.zip
    However, most of the other designs require the MicroZed 7020 SOM, including the designs supporting camera modules.
    Mario.
