MicroZed Hardware Design Getting "dmatest" to work on Microzed
  • Subscribers 360 subscribers
  • Views 259 views
ghalady
ghalady over 12 years ago
  Was wondering if anyone has tried using the "dmatest" of Xilinx Opensource Linux bundled with the Microzed. Though the boot process indicates:
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Registering SWP/SWPB emulation handler
dmatest: Started 1 threads using dma0chan0
dmatest: Started 1 threads using dma0chan1
dmatest: Started 1 threads using dma0chan2
dmatest: Started 1 threads using dma0chan3
dmatest: Started 1 threads using dma0chan4
dmatest: Started 1 threads using dma0chan5
dmatest: Started 1 threads using dma0chan6
dmatest: Started 1 threads using dma0chan7
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
mmc0: new high speed SDHC card at address 1234
mmcblk0: mmc0:1234 SA04G 3.63 GiB
mmcblk0: p1
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
However, when trying to run the dmatest, as posted on
https://www.kernel.org/doc/Documentation/dmatest.txt
at the "zync"prompt, I get:
zynq> dmatest.channel=dma0chan0 dmatest.timeout=2000 dmatest.iteration
s=1 dmatest.run=1
-/bin/ash: dmatest.channel=dma0chan0: not found
zynq>
Or trying it as a module :
zync> modprobe dmatest channel=dma0chan0 timeout=2000 iterations=1 run=1
zynq> modprobe dmatest channel=dma0chan0 timeout=2000 iterations=1 run
=1
modprobe: chdir(3.8.0-xilinx): No such file or directory
Would appreciate if anyone can share how to run the dmatest on Microzed.
Girish Halady
