MicroZed Hardware Design Rev F07 net length document
  • Replies 14 replies
  • Subscribers 362 subscribers
  • Views 2299 views
xzsawq21
xzsawq21 over 8 years ago
Hello
I want to know about the Rev F07 net length.
I found and downloaded Rev B net length document. is there any differences between Rev B and Rev F net length?
I'm working with high Speed ADC and DAC (200MSPS) and I really need it.
  • jafoste4
    jafoste4 over 8 years ago +1
    Hello xsawq21, We have the Rev F Net length report available for your download located here http://zedboard.org/support/documentation/4736 --Josh
  • jafoste4
    My apologies, for some reason I just assumed PicoZed. I have made a request for the Net Length Report. --Josh
  • jafoste4
    jafoste4 over 8 years ago +1 verified
    Hi, I just posted the MicroZed RevF Net Length Report in the same location as the RevB Report. Regards, Josh
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello xsawq21,
    --Josh
  • xzsawq21
    0 xzsawq21 over 8 years ago in reply to jafoste4
    my board is MicroZed ZYNQ 7020.
    even in the above link, I couldn't find anything about the Rev F07.
  • jafoste4
    --Josh
  • jafoste4
    Josh
  • xzsawq21
    Dear
    I want to rout  high speed LVDS pairs to MicroZed (200MHz)
    I checked all the documents. the below pic is a part of the below document:
    http://zedboard.org/sites/default/files/documentations/5274-MicroZed-Carrier-Design-Guide-rev-1-5-V1.pdf
    as you see I have to tune the lengths within 10mils (no problem) but when I checked the Length Document that you have uploaded before I see 1 cm mismatch between the pairs on the MicroZed SOM!!!
    even in the first blanket we have 16mm of mismatch between one pair (P to N)!!!
    between the first and second pairs there is 24mm of mismatch!!!  it's disaster!
    for JX1:
    for JX2:
  • xzsawq21
    Dear
        http://zedboard.org/sites/default/files/documentations/5274-MicroZed-Car...
        for JX1:
        for JX2:
  • xzsawq21
    Dear
        http://s9.picofile.com/file/8313829926/pairs.PNG
        for JX1:
         http://s8.picofile.com/file/8313829900/jx1.png
        for JX2:
    http://s8.picofile.com/file/8313829918/jx2.png
  • jafoste4
    Have you reviewed the MicroZed Carrier Design Guide?
    http://zedboard.org/support/documentation/1519
    --Josh
  • xzsawq21
    Yes, Actually I have sent you a pic of this document above.
    one of pins I have showed you is PUDC that I have marked it in the table with a red blanket. it's OK. I don't use it at all for the LVDS.
    but my question is: I can tune all the lengths on my carrier board within 10 mils, but there is a mismatch in the lengths around 1cm on the MicroZed SOM!
    what should I do?
  • xzsawq21
    there is no answer?
    Actually this mismatch is negligible?
