MicroZed Hardware Design microzed JX1 JX2 pins from differential to single end
  • Subscribers 361 subscribers
  • Views 460 views
exds75
exds75 over 8 years ago
Hi Microzed,
I am trying to use Microzed JX1 and JX2 pins (from BANK 34/35/13) as single ended instead of differential.
Read other posts on this forum, such as
http://zedboard.org/content/jx1jx2-track-impedance
http://zedboard.org/content/using-pmod-jc-and-jd-single-ended
But still not clear. Do I need to physically change the resistors on the Microzed board, or how can I control the impedance to make JX1 and JX2 pins as single ended ?
It will be a great help if Microzed expert provides design project in vivado/sdk for me to follow.
Please advise, thanks in advance
Mike
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Mike,
    The 50 Ohm impedance is controlled by the routing done on your carrier board. No Physical resistor needs to be placed for that.
    --Josh
