MicroZed Hardware Design Unable to find custom IP Driver in BSP Settings
  • Subscribers 362 subscribers
  • Views 1109 views
Im new to the MicroZed and I was trying the Zynq book tutorial using Vivado 15.4 and Microzed 7010 on a Windows 7 64-bit operating system.
The exercice was about creating a custom IP for led_controller ( exercice 4A) and I was following the exact same steps until the step where is asked to add the led_controller driver the the BSP repository I followed it carefully but when I open the Board Support Package window and selects drivers from left-hand menu, I didnt find the led_controller_0 component as I should!
Any help would be appreciated. thx.
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Fourat,
    Looking at Zynq Book I see the latest version is designed to use Vivado 2015.1. Typically something changes from Version to Version within the tool. I suggest you download Vivado 2015.1 and try your exercisie using that. Let me know how it goes.
    - Josh
    0 e14 Contributor over 10 years ago in reply to jafoste4
    Thx Josh,
    i solved the issue, I launched SDK from the start menu ( not from vivado), i created a new board support package which i gave the same name as SDK automatically does and i included the bitstream.
    And it worked, the new IP driver is now included in the drivers list.
