MicroZed Hardware Design SPI Interface
  • Subscribers 362 subscribers
  • Views 564 views
SPI Interface
vatsalnaik
vatsalnaik over 9 years ago
I am trying to transfer Hex values using SPI and using MOSI pin which is on PMOD connector of MicroZed standard board.
I am able to get the signal when I create an FSBL application and boot it from SD card but When I try to run the program on hardware using SDK I am not seeing any signal. I don't know why is this happening. This is strange! Anyone has an idea what is missing?
Thank you.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Vatsalnaik,
    I  was given the go ahead to send you an un release reference design that demonstrates the use of the PS SPI controller. Please refer to your private messages.
    --Josh
  • vatsalnaik
    0 vatsalnaik over 9 years ago
    Problem with the Boot configuration. It should be in JTAG Boot configuration to make it work.
    Thank you
