MicroZed Hardware Design MicroZed software push-button interrupt
  • Subscribers 362 subscribers
  • Views 1440 views
ewasserm
ewasserm over 8 years ago
Hello!
I'm using the MicroZed 7010 board, with Xilinx SDK 2015.4.
I'm trying to write a simple C code that will flash the LED when a push-button interrupt occurs.
The status readings all report success, but when I press the button, nothing happens... What am I missing?
BTW, I saw the famous Adam Taylor’s MicroZed Chronicles blog:
https://forums.xilinx.com/t5/Xcell-Daily-Blog/More-About-MicroZed-Interrupts-Adam-Taylor-s-MicroZed-Chronicles/ba-p/398357
I have downloaded and tried his code - it doesn't work either!
I would be happy to get help with this. Thank you all!
my code goes as follows:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include "platform.h"
#include "xgpio.h"
#include "xgpiops.h"
#include "xparameters.h"
#include "xstatus.h"
#include "Xscugic.h"
#include "xil_exception.h"
static XGpioPs my_Gpio;
static XScuGic my_Gic;
static void USR_button_ISR(void *CallBackRef);
int main()
  init_platform();
  XGpioPs_Config *GPIO_Config;
  GPIO_Config = XGpioPs_LookupConfig(XPAR_PS7_GPIO_0_DEVICE_ID);
  int status;
  status = XGpioPs_CfgInitialize(&my_Gpio, GPIO_Config, GPIO_Config->BaseAddr);
  if (status == XST_SUCCESS)
printf("XGpioPs configuration successful! \n\r");
  else
printf("XGpioPs configuration failed! \n\r");
  XGpioPs_SetDirectionPin(&my_Gpio, 47, 1); // board LED, output
  XGpioPs_SetOutputEnablePin(&my_Gpio, 47, 1);
  XGpioPs_SetDirectionPin(&my_Gpio, 51, 0); // USR button, input
  XScuGic_Config *Gic_Config;
  Gic_Config = XScuGic_LookupConfig(XPAR_PS7_SCUGIC_0_DEVICE_ID);
  status = XScuGic_CfgInitialize(&my_Gic, Gic_Config, Gic_Config->CpuBaseAddress);
    printf("GIC configuration successful! \n\r");
    else
    printf("GIC configuration failed! \n\r");
  Xil_ExceptionInit();
  Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT, (Xil_ExceptionHandler)XScuGic_InterruptHandler, &my_Gic);
  status = XScuGic_Connect(&my_Gic, XPS_GPIO_INT_ID, (Xil_ExceptionHandler)USR_button_ISR, (void *)&my_Gic);
  printf("Interrupt handler connection successful! \n\r");
  else
  printf("Interrupt handler connection failed! \n\r");
  XGpioPs_SetIntrTypePin(&my_Gpio, 51, XGPIOPS_IRQ_TYPE_EDGE_RISING);
  //XGpioPs_SetCallbackHandler(&my_Gpio, (void *)&my_Gpio, (XGpioPs_Handler)USR_button_ISR);
  XGpioPs_IntrEnablePin(&my_Gpio, 51);
  XScuGic_Enable(&my_Gic, XPS_GPIO_INT_ID);
  Xil_ExceptionEnable();
  printf("waiting...\n");
  while (1)
  cleanup_platform();
  return 0;
static void USR_button_ISR(void *CallBackReff)
  XGpioPs_WritePin(&my_Gpio, 47, 1);
  sleep(5);
  XGpioPs_WritePin(&my_Gpio, 47, 0);
  • jafoste4
    0 jafoste4 over 8 years ago
    In your vivado hardware design did you enable MIO 47(ps led D3)?
    --Josh
  • ewasserm
    0 ewasserm over 8 years ago in reply to jafoste4
    Hi, yes I did - if you are referring to this option is the PS7 IP configuration window:
  • ewasserm
    0 ewasserm over 8 years ago in reply to ewasserm
    Zynq PS block configuration-> MIO configuration -> I/O Peripherals -> GPIO -> enable GPIO MIO
  • ewasserm
    The problem may have been an "unclean" interrupt flag, so I have added the command
    XGpioPs_IntrClearPin(&my_Gpio, 51);
    in USR_button_ISR and during the setup in the main program.
    Thanks for your help!
