MicroZed Hardware Design microzed industrial Board definition files
  • Subscribers 361 subscribers
  • Views 467 views
I need to switch from a commercial grade MicroZed Board to an Industrial grade one. I can't find the Industrial Board definition file, is it available? If no, can I use the same hdf file and a new bitstream generated for the Industrial Zynq device?
In other words, changing from commercial to industrial device requires also changing configuration for the ARM and memory timing?
Francesco
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Francesco,
    Changing from commercial to industrial devices does not require you to change the board definition file. In other words. you can use the same board definition file that you were using for the commercial SOMs on the industrial SOMs.
    --Josh
