MicroZed Hardware Design MicroZED and Embedded Timing Codes in YCrCb
  • Subscribers 360 subscribers
  • Views 263 views
I am using the MicroZED Embedded Vision Dev Kit.  This kit takes an HDMI input through the ADV7611 receiver and spits out an YCrCb 4:2:2 signal.  Since the development board schematic shows the hsync, vsync, clock, etc. signals out of the ADV7611 as no-connects, I am assuming the board is set up to embed those signals in the 16 bit video bus.  However, I cannot find an IP core to extract the signals for use in other Xilinx IP cores.  Can anyone help me out?  What core do I use to extract the clock, syncs, etc?
  • albertabeef
    0 albertabeef over 11 years ago
    In the Vivado IPI block design, the "embv_hdmii_yuv422" sub-system contains a core called "embv_hdmi_in" that extracts the embedded sync codes from the 16 bit data stream.
    The "embv_hdmi_in" core is provided as VHDL source, so check out the code to see how the embedded syncs are being extracted.
    Hope this helps !
    Mario.
