MicroZed Hardware Design related to AES-Z7MB-7Z010-G
  • Subscribers 361 subscribers
  • Views 300 views
wen_jian
wen_jian over 8 years ago
we use a AES-Z7MB-7Z010-G as part of our design circuit to control motor and related products. the fution test ok ,but one thing puzzled us .
1. if we power on the motor's power firstly(including 110V and 24V),the AES-Z7MB-7Z010-G can not start correctly.
2.only when we power on our power source firstly, then power on the motor source, the AES-Z7MB-7Z010-G can start correctly.
anything here can tell me where is wrong ?which direction should we check ?
thanks
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Wen,
    It appears you may be stressing IO pins on your MicroZed which is causing it to improperly power up when you power your motor control circuit first. Make sure you are not backfeeding/ have the ideal circuit protection on all pins to the MicroZed else you may be damaging your MicroZed.
    --Josh
