MicroZed Hardware Design Wilink8 Adapter integartuin with Microzed
  • Subscribers 362 subscribers
  • Views 467 views
100aditya
100aditya over 10 years ago
Dear Sir
              As per Wilink8 adpater it can be integrated with Zync series boards like microzed ,zedboard etc. You can find this information here http://zedboard.org/product/wilink-8-adaptor.
On above web page there is Document named Microzed mster script.zip. Upon unzip this file you will get a script file. In this file there is one script command which upon execution callling the following :
"git clone git://git.ti.com/wilink8-wlan/build-utilites.gi"
But upon execution of above command following error is coming:
fatal error:unable to connect git.ti.com:
git.ti.com[0: 198.47.29.151] error = connection refused.
Please tell me how to overcome this.
Regards
ADITYA
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Aditya,
    I am unsure why you are getting this issue. I have verified that the TI GitHub repo is there. I am not sure why the script is failing. Unfortunatly at this time we do not have the bandwidth to help you with this issue. However I have found three other sources that may be of help to you.
    Here is a post you may find helpful : http://zedboard.org/content/steps-get-wlink8-working-using-petalinux-picozed
    Since this is a TI product you should be able to get support there : http://www.ti.com/guidedsupport/docs/supporthome.tsp
    Also here is TI's Linux Drivers : http://www.ti.com/tool/wilink8-wifi-nlcp?keyMatch=wilink8%20linux&tisearch=Search-EN-Everything
    Hope this helps!
    --Josh
  • 100aditya
    0 100aditya over 10 years ago in reply to jafoste4
    HI Josh,
                 Thanks agian. In mine college campus to access the internet we have to do mannual proxy setting in our mozila firefox browser. I read yesterday on the internet and also posted mine problem to TI but there response is not very effective. So it might be possible that because of Proxy setting i am not able to run the git clone command. Do you have any idea about this???? How to overcome such kind of proxy setting to access git repository????
         Anyhow the links that you have sent above is seemed to be very much effective and helpful.Definitely i will look into this. But right now i have started following Silica ArchiTech Yocto Linux for ZedBoard Community Projecht .So let me try out this first.
    Regards
    Aditya
