MicroZed Hardware Design MicroZed Product Change Notices
  • Subscribers 361 subscribers
  • Views 1343 views
bhfletcher
bhfletcher over 10 years ago
Please subscribe to this thread if you would like to receive notifications of Product Change Notices (PCN) related to MicroZed.
Bryan
  • jafoste4
    jafoste4 over 8 years ago +1
    Hello, An issue was found with the current Rev G MicroZeds. JT4 should be a 1k ohm value while it is currently 0 ohm. Please refer to this post http://zedboard.org/content/query-jt4-value-microzed-rev…
  • bhfletcher
    0 bhfletcher over 10 years ago
    PCN16002 - Zynq DDR3 Memory Update, 10 March 2016
    PCN16003 - Zynq SOM Manufacturing Location Update, 10 March 2016
    Bryan
  • jafoste4
    0 jafoste4 over 8 years ago
    http://zedboard.org/content/query-jt4-value-microzed-rev-g
    We are working on generating an errata with this information.
    Thank you,
    Josh
  • bhfletcher
    0 bhfletcher over 7 years ago
    PCN14001 - Part Numbering Methodology Change, 2 May 2014
    The extended temperature (-E) part numbers will be obsoleted and replaced with Industrial temperature (-I) part numbers. No physical changes will be made to the product.
  • bhfletcher
    PCN14002 - MicroZed Board Input Voltage Support, 27 June 2014
    Starting with BOM revision F-06 all Capacitors attached to the input power rail will be rated at 16V or above.
  • bhfletcher
    PCN15002 - QSPI Chip Select Resistor Change, 8 June 2015
    The QSPI Chip Select pullup resistor value on all product lines have been increased from 240 ohms to 4.99K ohms.
  • bhfletcher
    PCN 17002 - MicroZed Rev F to Rev G, 21 August 2017
