MicroZed Hardware Design MicroZed step file and EMI
  • Subscribers 362 subscribers
  • Views 600 views
xzsawq21
xzsawq21 over 8 years ago
Hello
I'm using Altium Designer v17 to design a complicated carrier board, there are many RF connectors and IC on the board.
I have found the dimension of the MicroZed  in your website, but for checking the collision on my carrier board it's better to check the step file, is there such step file? (I'm using MicroZed RevF07).
another question is:
when I want to place the MicroZed on my carrier board, there are some IC below the MicroZed.
(I mean beneath the secondary side of below blue ovals)
http://s8.picofile.com/file/8314179192/font_view.jpg
how many layers did you use? is there any solid, unified ground plane? (for checking the EMI). is there any big EMI issue on the bottom side of MicroZed?
Best Regards
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Xzsaw21,
    We actually have the step files already provided on the web. Please look at the the documentation page for MicroZed and refer yourself to the Mechanical Drawings section 3D model. http://zedboard.org/support/documentation/1519
    A layout PDF is also available for you on that page.
    --Josh
  • xzsawq21
    0 xzsawq21 over 8 years ago
    Hi again :)
    I've downloaded MicroZed step file and used it in Altium Designer. but the color of 3D Body is green. could you please export MicroZed file to a step file with Red color? I mean similiar to a real MicroZed board.
