MicroZed Hardware Design Programming MicroZed board (PL) through SD card
  • Subscribers 361 subscribers
  • Views 454 views
100priya
100priya over 8 years ago
Hi
I need help in programming MicroZed board for standalone. I have designed  IPs in Vivado Design Suite and now I need to test it on MicroZed board. I don't have a Jtag cable. Therefore, I decided to program the SD card. Also, I am using breakout carrier card.
I created a block design using two of my IPs, created a constraint file (for taking output from a pin in CON1 port of carrier card), generated bitstream, exported the hardware(bitstream included) and launched SDK. Then within the SDK, I created a BSP with fat file system library. After this I created a FSBL application and added "ddr" to its available memory region in lscript.id. Then I created boot image for the FSBL application. [This procedure was explained in Adam Taylor's blog]
I copied the BOOT.bin file to SD card and inserted the SD card into the MicroZed board. I used breakout carrier card for powering the MicroZed board. As I powered it after inserting SD card, the blue LED  glowed. But i couldn't get any output from the CON1 in carrier card. Can anyone explain what I am missing.
PS: I have already tested the IPs on Zedboard and got correct results.
Thanx in advance!
Priya
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello priaya,
    When you tested this on Zedboard did you also boot it over SD card? Or did you do it over Jtag also? If you did it over Jtag, please try doing it over SD card and report back if you got similar results as you did on MicroZed.
    Josh
