MicroZed Hardware Design Error while running demo project on AES-FMC-MC4-AR0231AT-G!
  • Subscribers 361 subscribers
  • Views 614 views
wertyu7878456
wertyu7878456 over 4 years ago
I bought AES-FMC-MC4-AR0231AT-G from Avnet(AES-FMC-MC4-AR0231AT-G by Avnet Engineering Services Evaluation & Development Kits | Avnet) this month, and run the demo project from MicroZed_IIoT_Pulsar_I2C_Tutorial_PUL7 (avnet.com) on our ZCU102.
1.
It should have an output but actually an error on my ZCU102.
[1] 2676
root@xilinx:/media/card# [vcap_gmsl] vcap_gmsl_init ...
[vcap_gmsl] csi_set_act_lanes ...
[vcap_gmsl] v4l2_csi_set_ctrl ...
[vcap_gmsl] V4L2_CID_TEST_PATTERN ... 0
[vcap_gmsl] SET_CTRL : ID=0x009F0903, VALUE=0x00000000 ...
[vcap_gmsl] V4L2_CID_EXPOSURE ... 1339
[vcap_gmsl] SET_CTRL : ID=0x00980911, VALUE=0x0000053B ...
[vcap_gmsl] V4L2_CID_ANALOGUE_GAIN ... 7
[vcap_gmsl] SET_CTRL : ID=0x009E0903, VALUE=0x00000007 ...
[vcap_gmsl] V4L2_CID_GAIN ... 512
[vcap_gmsl] SET_CTRL : ID=0x00980913, VALUE=0x00000200 ...
[vcap_gmsl] V4L2_CID_VFLIP ... 0
[vcap_gmsl] SET_CTRL : ID=0x00980915, VALUE=0x00000000 ...
[vcap_gmsl] V4L2_CID_HFLIP ... 0
[vcap_gmsl] SET_CTRL : ID=0x00980914, VALUE=0x00000000 ...
[vcap_gmsl] vcap_gmsl_ops_set_media_ctrl ...
[vcap_gmsl] vcap_gmsl_find_sensor_res ...
[vcap_gmsl] vcap_gmsl_ops_set_frame_rate ... NOT IMPLEMENTED YET ...
/dev/video2
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
/GstPipeline:pipeline0/GstKMSSink:kmssink3: display-width = 3840
/GstPipeline:pipeline0/GstKMSSink:kmssink3: display-height = 2160
/GstPipeline:pipeline0/GstKMSSink:kmssink2: display-width = 3840
/GstPipeline:pipeline0/GstKMSSink:kmssink2: display-height = 2160
/GstPipeline:pipeline0/GstKMSSink:kmssink1: display-width = 3840
/GstPipeline:pipeline0/GstKMSSink:kmssink1: display-height = 2160
/GstPipeline:pipeline0/GstKMSSink:kmssink0: display-width = 3840
/GstPipeline:pipeline0/GstKMSSink:kmssink0: display-height = 2160
/GstPipeline:pipeline0/GstV4l2Src:v4l2src3.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUY2, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUY2, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter3.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUY2, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstKMSSink:kmssink1.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUY2, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUY2, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUY2, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUY2, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstKMSSink:kmssink0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUY2, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUY2, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt601
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not read from resource.
Additional debug info:
../../../git/sys/v4l2/gstv4l2bufferpool.c(1064): gst_v4l2_buffer_pool_poll (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
poll error 1: Input/output error (5)
Execution ended after 0:00:00.000531443
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
2. Another mistake is on this part:
When I build gstdemo, it shows:
Building target: gstdemo
Invoking: ARM A53 Linux gcc linker
aarch64-linux-gnu-gcc -L=/lib -L=/usr/lib -L=/usr/lib/glib-2.0 -L=/usr/lib/gstreamer-1.0 --sysroot= -Xlinker -rpath-link=/lib -Xlinker -rpath-link=/usr/lib -o "gstdemo"  ./main.o   -lglib-2.0 -lgstreamer-1.0 -lgobject-2.0 -lgstvideo-1.0
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: cannot find crt1.o: No such file or directory
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: cannot find crti.o: No such file or directory
makefile:35: recipe for target 'gstdemo' failed
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: cannot find -lglib-2.0
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: cannot find -lgstreamer-1.0
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: cannot find -lgobject-2.0
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: cannot find -lgstvideo-1.0
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: cannot find -lc
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: cannot find crtn.o: No such file or directory
collect2: error: ld returned 1 exit status
make: *** [gstdemo] Error 1
I need your after-sale service! Thanks in advance!
