MicroZed Hardware Design MicroZed GPIOs
  • Subscribers 359 subscribers
  • Views 1606 views
  • avnet boards
MicroZed GPIOs
e14 Contributor over 2 years ago
I’m using a MicroZed 7Z010 with Ubuntu v18.04. Is there a way to check which GPIO MIOs are enabled? when I use gpioinfo is shows me 118 lines, I don't think that is showing what is enabled.
Thank you,
  • flyingbean
    flyingbean over 2 years ago +2 suggested
    AMD/Xilinx did give a good demo on this topic: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842398/Linux+GPIO+Driver I did not mount a Ubuntu on Zynq before, but I did mount Linux on Zynq…
  • flyingbean
    0 flyingbean over 2 years ago
    Your question is not very clear. Was your project on MicroZed 7z010 running Ubuntu v18.04 or your Vitis project for MicroZed 7z010 built on Ubuntu v18.04?
    0 e14 Contributor over 2 years ago in reply to flyingbean
    It is on a MicroZed 7z010 running Ubuntu v18.04.
  • flyingbean
    The short answer is YES. However, you do need a skill to check that.
  • cstanton
    0 cstanton over 2 years ago in reply to flyingbean
    Would you mind providing a different explanation, because saying:
    Doesn't come across very well as an informative answer.
  • flyingbean
    I did not mount a Ubuntu on Zynq before, but I did mount Linux on Zynq. I think you might try these commands as below:image
    Good luck.
