MicroZed Hardware Design Microzed Connection Issue
  • Subscribers 360 subscribers
  • Views 861 views
  • xilinx
  • vivado
  • vitis
kpham
kpham over 2 years ago
I have just started using the Microzed 7020, and I've been trying to flash some example code on to the board, but I keep having this error when using Vitis 2024.1:
 The error message is:
"Could not find ARM device on the board for connection 'Local'. Check if the target is in:
  1. Split JTAG - No operations are possible with ARM DAP.
  2. Non JTAG bootmode - Bootrom may need time to enable DAP.
Please try again. Troubleshooting hints:
  1. Check whether board is connected to system properly.
  2. In case of zynq board, check whether Digilent/Xilinx cable switch settings are correct.
  3. If you are using Xilinx Platform Cable USB, ensure that status LED is green"
Tera Term seems to be able to recognize the COM port and the connection, but nothing is showing up on the terminal as well.
When I use Vivado 2024.1's hardware manager, it also doesn't seem to be able to connect to the board.
I've tried updating the drivers, but nothing works.
Could someone please point me in the right direction? Thank you very much.
