Mini-ITX Hardware Design System Kit
  • Subscribers 355 subscribers
  • Views 2040 views
System Kit
Is there enough space in the Mini-ITX Chassis to insert a PCIe card?
The picture of the chassis doesn't show that part, but the power supply and cabel seems to be very close.
Juergen
    e14 Contributor over 12 years ago +1 suggested
    You can only use mini PCIe card form factor in a Mini-ITX chassis. Full size PCIe cards cannot be used in Avnet Mini-ITX System Kit chassis. You can Google for PCIe cards designed to fit in a Mini-ITX…
    You can only use mini PCIe card form factor  in a Mini-ITX chassis. Full size PCIe cards cannot be used in Avnet Mini-ITX System Kit chassis. You can Google for PCIe cards designed to fit in a Mini-ITX chassis.
    Could someone please provide the Mini-ITX chassis dimensions for the Mini-ITX System Kit?
  • kuzzo
    0 kuzzo over 5 years ago
    test test v1
