Mini-ITX Hardware Design Reference Designs/Tutorials
  • Subscribers 354 subscribers
  • Views 781 views
Hello everyone,
I can't download any refence design for Mini-ITX board.
When I tried to open 'design_files.zip' (where should be all Vivado projects) it shows error.
Downloading projects separately is impossible.
Any ideas?
    There is an issue with the 'Download All' design files.zip but you should be able to download each of the reference design individually. You do need to be logged in the download files. Which reference design file did you have trouble downloading?
    -Gary
    Today I finally downloaded some reference projects. Earlier was a problem with login, I tried several times but it finished a failure.
    However I still can't download 'Embedded Standalone OS' for 7Z100, other links works fine.
    Hello Wojtek,
    I was able to download the "Embedded Standalone OS for 7Z100" Reference design with no issues. Please try the download again and let me know if there are any problems.
    -Gary
    I used IE instead of Firefox and everything works fine.
    Thanks for your support Gary.
