Mini-ITX Hardware Design ALI3 Display Reference Design error
  • Subscribers 354 subscribers
  • Views 441 views
I am attempting to follow the tutorial for the Zynq Mini-ITX (MITX): ALI3 Display Reference Design.
However, running the script make_mitx_ali3_sharp7.tcl generates a seemingly "empty" project.  The resulting block diagram has no IP blocks and is comletely empty. The wrapper file causes an error due to its lack of ports:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
entity mitx_ali3_sharp7_wrapper is
end mitx_ali3_sharp7_wrapper;
architecture STRUCTURE of mitx_ali3_sharp7_wrapper is
  component mitx_ali3_sharp7 is
  end component mitx_ali3_sharp7;
begin
mitx_ali3_sharp7_i: component mitx_ali3_sharp7
     port map (
end STRUCTURE;
What could be causing this reference design to not generate properly?
Thank you
  • zedhed
    0 zedhed over 10 years ago
    Hi ctfelten,
    What version of Vivado Design Suite are you launching the script in?
    Do you see any errors reported in the TCL console while the project is being built?
    -Kevin
