Mini-ITX Hardware Design Cable drivers to detect Mini-ITX on Ubuntu workstation?
  • Subscribers 354 subscribers
  • Views 610 views
armendzh
armendzh over 10 years ago
I am using Ubuntu 14.04 as my workstation for working with AVNET Mini-ITX 7z100 board.
I was trying to boot prebuilt image example for Mini-ITX 7z100 board via jtag (petalinux-boot --jtag), however I am getting an error stating that no supported FPGA device found. I guess it is because I don't have cable drivers (which I was able to install on Windows) properly configured.
How do I fix this error and be able to recognize Mini-ITX board?
Error in startup script:
No supported FPGA device found
    invoked from within
"::tcf::eval -progress ::xsdb::print_progress {::tcf::cache_enter tcfchan#0 {tcf_cache_eval {process_tcf_actions_cache_client ::tcfclient#0::arg}}}"
    (procedure "::tcf::cache_eval_with_progress" line 2)
    invoked from within
"::tcf::cache_eval_with_progress [dict get $arg chan]  [list process_tcf_actions_cache_client $argvar] $progress"
    (procedure "process_tcf_actions" line 1)
    invoked from within
"process_tcf_actions $arg ::xsdb::print_progress"
    (procedure "fpga" line 350)
    invoked from within
Do I need to install digilent drivers? (found in Xilinx/2015.2/xicom/cable_drivers/lin64/install_script/)
    This thread from the Xilinx Community forum on installation and licensing might be helpful:
    https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2015-2-Cable-driver-installation-problem/td-p/642140
    -Gary
