Mini-ITX Hardware Design FMC front panel access
  • Subscribers 354 subscribers
  • Views 409 views
Is there any way to get access to the front panel of an FMC board installed in the system kit?   The image of the unit makes it look like the front panel would sit right in the middle of the board, facing the back of the enclosure.  Would you just be on your own to tie cables in the enclusure, and have them exposed loose out the back side?
    The FMC front panel faces the chassis back panel so that the FMC I/O can be accessed via the back panel.
