Mini-ITX Hardware Design Device Tree
  • Subscribers 354 subscribers
  • Views 686 views
Device Tree
Hi ,
I would like to build a custom device tree for my miniITX zc7100 device. Can anyone provide me with a base device tree and procedure for modifying the device tree with repect to new devices plugged to the AXI Interface
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello MiniITX_learn,
    You can try using the device tree generator in SDK to build you basic device tree from your existing hardware platform, see link below.
    http://www.wiki.xilinx.com/Build+Device+Tree+Blob
    You could also use the Device Tree Compiler (DTC) on any existing DTB to decompile to source (you will lose all the layering and nice names though) see link below
    http://www.wiki.xilinx.com/Build+Device+Tree+Compiler+(dtc)
    Source for device trees for our PetaLinux releases is part of the BSP, so it gets built into the project you created form that. For Pulsar Linux the source is part of the wr-core hierarchy on OpenSourceLabs, or you can use DTC to decompile the DTB file on the uSD image.
    --Josh
