Mini-ITX Hardware Design Communicating between two boards? Which DAC and ADC works?
  • Subscribers 354 subscribers
  • Views 592 views
armendzh
armendzh over 10 years ago
What Digital to Analog and Analog to Digital adapter boards can I use to be able to communicate between two Mini-ITX boards?
I will be generating some signals on on one system and decode it after ADC on another.
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Armendzh,
    We don't have an easy solution for the Mini-ITX. Typically we use a PMOD adapter to solve this problem, however the Mini-ITX does not have any PMOD adapters available on it. So you will need a FMC Card. Here is a link to the FMC Card's Xilinx offers, however most of these solutions are fairly expensive.
     http://www.xilinx.com/products/boards-and-kits/fmc-cards.html
    If you are looking for a cheaper alternative you could find a FMC Card with PMOD adapter then use a PMOD to communicate between the two Mini-ITX boards.
    Here is a FMC Card from Digilent with PMOD adapters that you may find useful.
    http://store.digilentinc.com/fmc-ce-basic-i-o-expansion-board/
    Maxim Integrated and Analog Devices have various selections for PMODs you can choose from to suit your needs(see links below)
    Maxim Integrated - https://www.maximintegrated.com/en/app-notes/index.mvp/id/5468
    Analog Devices - http://www.analog.com/en/products/analog-to-digital-converters/ad-converters.html#all-ad-converters
    - Josh
