Mini-ITX Hardware Design Issue with PSiP Power Module of Mini-ITX-7Z-ASY-G
  • Subscribers 355 subscribers
  • Views 1289 views
  • issue with psip power module of mini-itx-7z-asy-g
nafiseh
nafiseh over 7 years ago
Hi all,
We have a Mini-ITX-7Z-ASY-G board, it is connected to the power module Panasonic PSiP. I have an issue that when I turn on the FPGA board, the power module doesn't turned on and it doesn't work. Can you please guide me how can I solve this problem?
  • ctammann
    ctammann over 7 years ago
    I assume you have the ATX supply connected to the board, as well as the Panasonic module mounted properly. What happens when you turn on the power switch? Does anything try to power up?
    Chris
  • nafiseh
    nafiseh over 7 years ago in reply to ctammann
    Yes, the Panasonic is mounted; When I turn on the FPGA board the fan becomes on, but the LED lights on Panasonic power module don't turn on and the output from Panasonic Power Module doesn't come up.
